The burners on top click and ignite, the broiler ignites, but when I put the oven on bake, nothing happens. No flame, nothing. I took the panel off and there is nothing going on at the ignitor, not flame, no glowing, nothing.
Could it be the ignitor?
Thanks for the help!
Most likely the problem is a bad igniter. Disconnect the igniter wires and check the igniter for continuity and check for 120 VAC to the igniter wile the control calls for Bake. If there is proper voltage or/and there is no continuity then the igniter is the culprit. - The igniter Part number: AP2150412
