Jimh64
#1 Posted : Tuesday, October 13, 2009 1:30:16 PM(UTC)
Jimh64
The burners on top click and ignite, the broiler ignites, but when I put the oven on bake, nothing happens. No flame, nothing. I took the panel off and there is nothing going on at the ignitor, not flame, no glowing, nothing.
Could it be the ignitor?
Thanks for the help!
#2 Posted : Tuesday, October 13, 2009 3:23:01 PM(UTC)
Most likely the problem is a bad igniter. Disconnect the igniter wires and check the igniter for continuity and check for 120 VAC to the igniter wile the control calls for Bake.
If there is proper voltage or/and there is no continuity then the igniter is the culprit.
- The igniter Part number: AP2150412
Thermador gas oven won't ignite/stay on (Oven Repair (including Ranges and Cooktops))
by 69GTFB 1/28/2013 11:57:57 AM(UTC)
Whirlpool Gas Oven won't Ignite (Oven Repair (including Ranges and Cooktops))
by davidshane 10/30/2012 11:25:32 AM(UTC)
Maytag gas oven won't ignite (Oven Repair (including Ranges and Cooktops))
by peterburns 9/12/2012 6:03:29 PM(UTC)
Whirlpool Gas Oven won't ignite (Oven Repair (including Ranges and Cooktops))
by nlmcswain 5/29/2009 3:12:27 PM(UTC)
