mwilli96
#1 Posted : Monday, November 22, 2010 4:50:35 AM(UTC)
mwilli96
Good morning, My daughter's oven quit working after a power outage a few months ago. I'm no appliance technician, but I suspect that a low-voltage situation exsisted which affected the controls. The top burners still work, but the oven won't ignite. If the spark module is fried, would the top burners still work? Ican change the module, but I wanted to be sure that's what is wrong with it. Would low voltage affect the gas valve for the oven? Thanks for your help. Mike
magician59
#2 Posted : Monday, November 22, 2010 7:00:48 AM(UTC)
magician59
You might be right about the power outage affecting the electronic control; but further diagnosis will confirm your gusee, or possibly keep you from spending unnecessary dollars on a good part. The oven chamber uses a different ignition source: a broil igniter, and a bake igniter (In the case of your daughter's range, they're both the same part number. You'll need to be able to check to see if you get 120VQC to the igniters when you select "BAKE". If no response from the control, or if the control responds, but no power to the igniters, replace the control. If you get a response AND power to the igniters; but no glow, replace the igniter(s) that don't glow.
Tell us what you find.
Part number: AP2990525
Whirlpool oven won't ignite unless unplugged and plugged back in. Thoughts? (Oven Repair (including Ranges and Cooktops))
by wbynum 12/20/2018 7:31:13 AM(UTC)
Oven won't ignite on bake initially but will after using broiler (Oven Repair (including Ranges and Cooktops))
by JeremySDMF 7/15/2015 11:06:20 AM(UTC)
Old Caloric oven won't ignite (Oven Repair (including Ranges and Cooktops))
by Alan McRae 6/17/2014 6:22:54 AM(UTC)
Thermador gas oven won't ignite/stay on (Oven Repair (including Ranges and Cooktops))
by 69GTFB 1/28/2013 11:57:57 AM(UTC)
Whirlpool Gas Oven won't Ignite (Oven Repair (including Ranges and Cooktops))
by davidshane 10/30/2012 11:25:32 AM(UTC)
Maytag gas oven won't ignite (Oven Repair (including Ranges and Cooktops))
by peterburns 9/12/2012 6:03:29 PM(UTC)
Whirlpool oven won't ignite after replacing igniter and valve (Oven Repair (including Ranges and Cooktops))
by Dave Mashburn 8/15/2012 9:57:46 AM(UTC)
Whirpool SC 465 - oven won't ignite... (Oven Repair (including Ranges and Cooktops))
by chappy801 5/22/2012 7:55:45 PM(UTC)
Kenmore Oven won't ignite (Oven Repair (including Ranges and Cooktops))
by nitramnaed 5/15/2012 6:57:11 AM(UTC)
KitchenAid oven won't ignite, except manually (Oven Repair (including Ranges and Cooktops))
by reneechgo 3/9/2012 3:46:03 PM(UTC)
Wall oven won't ignite (Oven Repair (including Ranges and Cooktops))
by Jeffjuiced 7/15/2010 12:02:17 PM(UTC)
Gas Oven Won't Ignite (Oven Repair (including Ranges and Cooktops))
by Jimh64 10/13/2009 1:30:16 PM(UTC)
by sandpointrick 9/16/2009 1:07:43 PM(UTC)
Amana Oven won't ignite (Oven Repair (including Ranges and Cooktops))
by MASOL 6/29/2009 5:43:20 AM(UTC)
by moby65 6/16/2009 6:08:14 PM(UTC)
