2 Pages12>
bdccjc
#1 Posted : Sunday, November 29, 2009 10:12:10 AM(UTC)
bdccjc
I have a kenmore HE3 dryer that won't start a cylce. When I press and hold the start button I hear a click. I have tested the door switch, motor control switch and belt switch. All test good. I recently replaced the main control board and thermistor about 6-8 months ago due to other issues. What to do now? Can a bad thermal fuse cause this? How do I test the thermal fuse? Should it read 0-2 ohms or open?
#2 Posted : Sunday, November 29, 2009 2:35:49 PM(UTC)
What to do now?
Cannot say, your model number is missing quite a few numbers so I cannot find any info on the unit. Please check it.
Yes, if there is a fuse in the motor's circuit. Usually there is. Often it is on the blower assembly.
Measure it with a meter. It should be 0 ohms. Be sure to unhook at least one side of it so that you do not read an alternate/parallel circuit path.
bdccjc
#3 Posted : Monday, November 30, 2009 5:31:07 AM(UTC)
bdccjc
Originally Posted by: denman Go to Quoted Post
What to do now?
The model number 110.82826102 Kenmore HE3
#4 Posted : Monday, November 30, 2009 5:57:59 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208557311.pdf
As you can see both the thermal fuse (I believe it will be on the blower) and the belt switch will stop power to the motor.
bdccjc
#5 Posted : Monday, November 30, 2009 6:09:16 AM(UTC)
bdccjc
Thanks for your help! Yes the thermal fuse is open. On my way now to the parts house to get a replacement. The belt switch tested good.
#6 Posted : Monday, November 30, 2009 9:47:48 AM(UTC)
Be sure to check and clean your vent system as this is the most common cause of this fuse blowing.
bdccjc
#7 Posted : Tuesday, December 1, 2009 6:12:11 AM(UTC)
bdccjc
After replacing the thermal fuse, and putting it all back together, I now have a a bad heating element. It has burned so hot that one of the loops burned and broke off. I also noticed that the plate that holds the heating element is black and charred, with 2 heat related cracks. When a thermal fuse goes out, is it common to have to replace the heating element as well, due to overheating. A thermal fuse is designed to shut the heating system down if it reaches to high of a temperature, correct?
#8 Posted : Tuesday, December 1, 2009 7:56:47 AM(UTC)
The opposite probably happened.
Sounds like the heating element burned out then shorted to the case and this took out the thermal fuse.
bdccjc
#9 Posted : Tuesday, December 1, 2009 8:16:41 AM(UTC)
bdccjc
Thanks again!
I hope this all there is to replace on this unit.
bdccjc
#10 Posted : Monday, December 7, 2009 9:05:34 PM(UTC)
bdccjc
Originally Posted by: bdccjc Go to Quoted Post
Thanks again!
Now my door will not stay shut and keeps coming open, stopping the cycle. It seems to be the clips in the door and where they meet with the prong on the machine. It stops the cycle when the door comes open. Is there an adjustment that I can make to the alignment of the door or can the clips/prong be replaced?
Kenmore HE3t noise at beginning of wash cycle (Washer Repair)
by Brenda McAlpine 7/31/2019 10:27:42 AM(UTC)
Kenmore HE3 dryer - no heat (Dryer Repair)
by tdalton 10/2/2017 1:20:19 PM(UTC)
kenmore he3 elite washer water temperature control (Washer Repair)
by E!iteH#3 7/24/2016 12:49:19 PM(UTC)
Kenmore HE3 rear drum support or spyder (Washer Repair)
by Faranks 5/18/2015 8:35:00 AM(UTC)
Kenmore HE3 washer - drum not rotating (Washer Repair)
by Garageguy 2/14/2015 1:45:42 PM(UTC)
Kenmore HE3t F2 error message (Washer Repair)
by MovingMountains 11/2/2014 6:04:18 AM(UTC)
Kenmore HE3 Washer Vibration (Garbage Disposer Repair)
by SarahStrain 9/21/2013 9:18:09 AM(UTC)
Kenmore HE3 - won't drain (Washer Repair)
by fms1974 12/15/2012 2:19:18 PM(UTC)
kenmore he3t, error code f28 (Washer Repair)
by bleonard 11/19/2012 11:15:17 AM(UTC)
Kenmore HE3 Dryer starts then stops (Dryer Repair)
by nowhere 1/13/2012 8:32:59 PM(UTC)
Kenmore HE3T F1 error (Washer Repair)
by kkoennecke 1/2/2012 3:59:25 PM(UTC)
Kenmore He3 Elite E1 Code (Dryer Repair)
by 1007 12/5/2011 4:49:26 AM(UTC)
baffle is loose - Kenmore HE3 Front Load Washer (Washer Repair)
by tripdip 6/8/2011 10:16:07 AM(UTC)
Kenmore HE3 Front Loader is filling with water when machine is OFF and not activated (Washer Repair)
by dat2disc 5/1/2011 6:10:15 AM(UTC)
Kenmore he3 smoking? (Dryer Repair)
by jfoynes 10/5/2010 6:35:18 AM(UTC)
2 Pages12>
