I have water on the floor on the freezer side. The freezer door was removed to move out of the house. I had a problem with the line that runs through the door but had it fixed I thought by a repair man. He had to cut sone of the tubing out because in the move it got ripped. I haven't used the refrigerator in three years because it stopped working. Plugged it in the day before Thanksgiving and it started to work again. Anyway I have water in front on freezer side in front. Is there anything I can check? I would like to know how the water flows to the door and icemaker. Where are there fittings I can check? I have the diagrams for it but they do not tell me how the lines and water run. Anyone? Thanks in advance,
Joe
THIS FORUM IS DEAD!!!!!!! |
