djjoey22
#1 Posted : Monday, November 30, 2009 10:17:07 PM(UTC)
djjoey22
I have water on the floor on the freezer side. The freezer door was removed to move out of the house. I had a problem with the line that runs through the door but had it fixed I thought by a repair man. He had to cut sone of the tubing out because in the move it got ripped. I haven't used the refrigerator in three years because it stopped working. Plugged it in the day before Thanksgiving and it started to work again.
Anyway I have water in front on freezer side in front. Is there anything I can check? I would like to know how the water flows to the door and icemaker. Where are there fittings I can check?
I have the diagrams for it but they do not tell me how the lines and water run. Anyone? Thanks in advance,
Joe
#2 Posted : Tuesday, December 1, 2009 2:38:51 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26R4CB1 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the manual for this unit
http://frigidaireservicetips.com/pdfs/398_8.pdf
Unfortunately, it is sort of useless when it comes to the mechanics of the unit so I am hoping the following will cover those or at least put you on the right track
http://frigidaireservicetips.com/pdfs/495_2.pdf
