SarahStrain
#1 Posted : Saturday, September 21, 2013 9:18:09 AM(UTC)
SarahStrain
My washing machine sounds like a jet plane during the spin cycle. Extremely loud. It does not move around a lot just makes a horrible racket. Any suggestions would be appreciated. Also just started to make a squeaking sound every now and then as the load is washing? I'm guessing something needs to be greased? Please advise.
HumboldtRepairMan
#2 Posted : Saturday, September 21, 2013 1:21:05 PM(UTC)
HumboldtRepairMan
Sounds like your bearing is going out which is common for whirlpool front loaders made in the last 7 years.........grab the metal drum when it's off and see if it moves between the plastic tub that surrounds it..........if it moves more then 1/4 of an inch your bearing is most likely bad. Here are some video's demonstrating a bad bearing. And if it is a bad bearing get rid of it it'll cost you more in labor and parts then it's worth.
he3 washer bad bearing - YouTube
