MONA SMITH
#1 Posted : Sunday, November 15, 2009 7:19:33 PM(UTC)
MONA SMITH
DRY WILL START RUN 2-3 SECOND THAN STOP. PUSH START BUTTON FEELS FUNNY AFTER SHUT OFF. THERE SEEMS TO BE A ELECTRICAL BURNING SMELL AT THIS TIME. JUMPED THE WHITE FUSE AT THE EXHAUST NO CHANGE, HEATED SENSOR BY EXHAUST IT CLICKED, NO CHANGE, PUSH START SWITCH HAS OMHS. TIMER TICKS BUT DOES NOT BUZZ.
DRY WAS DIRTY IN SIDE AND WE CLEANED IT OUT BUT NO CHANGE.:rolleyes: :confused:
#2 Posted : Monday, November 16, 2009 4:28:02 AM(UTC)
Here is your wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203979703.pdf
Your problem should not be related to the heating element etc.
I have no idea on this symptom
This could be the motor overheating. If the motor is overheating, it will trip it's internal thermal protect and you will not be able to restart it right away. The motor has to cool down for the protect to reset.
Try turning the drum by hand, should turn fairly easily. This is just in case the motor is overloaded but it is probably OK.
It sounds like the centrifugal switch for the motor's start winding is not opening. Then the start winding stays energized and the motor overheats.
This could be that the mechanism on the motor which activates the switch is clogged solid with dust.
If this was gone it would kill power to the unit so it would not even start.
Would not effect starting
Should have 0 ohms when pushed. Again it would not start at all if this was toast
Not sure what this means
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Dryer won't stay running after replacing parts (Dryer Repair)
by dlg56 11/6/2016 6:54:36 PM(UTC)
Dryer won't stay running... (Dryer Repair)
by Charlie.2loose@gmail.com 7/26/2015 7:29:52 AM(UTC)
Whirlpool Gold dryer won't stay running and no heat (Dryer Repair)
by swami69 4/7/2014 10:15:38 AM(UTC)
Dryer won't stay running (Dryer Repair)
by White72gs455 12/24/2013 1:19:55 PM(UTC)
Admiral Dryer Won't Stay Running (Dryer Repair)
by ravynfire 10/16/2012 6:51:07 AM(UTC)
by OKFREE 4/23/2011 7:35:37 AM(UTC)
by JimRumler 1/31/2011 11:28:26 AM(UTC)
by hollyparrish 1/26/2011 7:35:43 AM(UTC)
by timjmix11 10/5/2010 6:04:45 PM(UTC)
Dryer won't stay running. (Dryer Repair)
by nwpop05 1/13/2010 2:21:38 PM(UTC)
by Fixitchick 9/24/2009 4:12:27 PM(UTC)
by teetwofalcon 8/8/2009 3:34:19 AM(UTC)
GE Electric Dryer won't stay running (Dryer Repair)
by bdrg 1/8/2009 8:09:06 AM(UTC)
Bosch dryer won't stay running - sometimes (Dryer Repair)
by jhabetler 3/2/2008 1:17:47 PM(UTC)
