dustin22
#1 Posted : Tuesday, October 27, 2009 8:35:59 PM(UTC)
dustin22
Calypso Dryer not heating. Prior to not heating, would sometimes run for couple of minutes, then cut off with error message- would have to restart. Seemed to be taking long time to dry clothes. Then recently, was drying too hot. Now, not drying at all. We cleaned lots of lint from the dryer, including the lint housing and duct and replaced thermal cut-off and other part that comes with it. Tested heating element and getting 250 volts but not getting hot. Does this mean that the heating element needs to be replaced?? Any other tests that we could perform? Thank you very much!
#2 Posted : Wednesday, October 28, 2009 12:40:35 AM(UTC)
Replacement parts for WHIRLPOOL GEW9868KL0 | AppliancePartsPros.com
Yes.
You can double check it using resistance on your meter.
Remove one wire from one side of the heater and check it, should be 10 ohms approximately.
Not really you will not know if you have another problem until you get the heater up and running.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
