hb6306
#1 Posted : Thursday, September 10, 2009 12:55:10 PM(UTC)
hb6306
I replaced the electrical control unit. After plugging in, all the LED's light up and blink. How do I reset the electronics?
sidfink43
#2 Posted : Sunday, September 13, 2009 5:30:57 AM(UTC)
sidfink43
GE does not allow anyone outside of GE to have access to its tech info so I do not know if there is a reset procedure.
There should be technical information inside the console there. If that does not tell you, or if the info is missing I can only suggest you contact GE and see if they can hellp you.
Sorry not to be more helplful. Good luck.
applianceman
#3 Posted : Sunday, September 13, 2009 7:09:03 AM(UTC)
applianceman
I am assuming you replace the control panel correct?
If so on the old control you have a plug with just a jumper wire. Often people will leave this plug off because the wires don’t connect to anything on the washer. This is the model select plug and if it is not installed on the new control all it will do is blink the lights. Hope this helps!
Clothes Washer Repair Guide
hb6306
#4 Posted : Tuesday, September 15, 2009 6:57:30 AM(UTC)
hb6306
:) I did replace the control panel, and you are absolutely right. Thanks!
Possible dryer electrical problem (Dryer Repair)
by Dmillbhawk 8/1/2013 10:43:43 AM(UTC)
Do I have electrical problem? Soap dispenser? (Dishwasher Repair)
Belarus roger20 3/13/2012 3:42:47 PM(UTC)
electrical problem (Oven Repair (including Ranges and Cooktops))
by robertwgeorge 2/9/2012 6:44:19 PM(UTC)
electrical problem (Washer Repair)
by garycart 4/4/2011 4:57:29 PM(UTC)
Electrical problem (Dishwasher Repair)
by capndavid2001 8/31/2010 6:08:08 AM(UTC)
Maytag Dryer - first noise, now also electrical problem (Dryer Repair)
by RobBroekhuis 11/7/2009 2:23:58 PM(UTC)
Icemaker front panel electrical problem (Refrigerator & Freezer Repair)
by ttvor 6/20/2009 2:10:55 PM(UTC)
Electrical Problem (Garbage Disposer Repair)
by Debra Carlin 11/15/2008 6:04:36 PM(UTC)
Electrical problem (Refrigerator & Freezer Repair)
by mcbdallas 2/19/2008 11:27:42 AM(UTC)
