2 Pages12>
Tim Lim
#1 Posted : Tuesday, September 2, 2008 7:12:04 AM(UTC)
Tim Lim
I've replaced the ERC touch pad, part AP172494 and F1 error code is still flashing and beeping. When this happens, the touch pad is frozen except for th oven cancel button.
What else should I do?
Thanks,
tim
#2 Posted : Tuesday, September 2, 2008 7:02:09 PM(UTC)
Hi Tim,
I need you to confirm which part did you replace. You said "touch pad" but the part number you posted (AP172494) s for the ERC aka clock.
Tim Lim
#3 Posted : Wednesday, September 3, 2008 7:15:00 AM(UTC)
Tim Lim
Sorry Gene, it's the ERC that I've replaced.
#4 Posted : Wednesday, September 3, 2008 1:12:26 PM(UTC)
Tim,
According to the tech sheets for your range the error code "F1" means "Shorted input pad" and correction is to replace the membrane switch. Replacing the ERC would not fix it.
In order to provide the right part number for the membrane switch I need the color of the control panel.
Here are the break down diagrams for the Amana range Model ARTSC8651SS
Tim Lim
#5 Posted : Wednesday, September 3, 2008 3:42:42 PM(UTC)
Tim Lim
It's black and part # AP172494.
I've already ordered part#AP93441-Membrane, switch panel (bl). I hope it's the right one.
Tim
#6 Posted : Wednesday, September 3, 2008 4:26:45 PM(UTC)
Yes Tim, this the right part number. Good luck and keep us posted.
Tim Lim
#7 Posted : Monday, September 8, 2008 2:01:04 PM(UTC)
Tim Lim
Thanks for your help Gene. I got an replace the part and is now working.
#8 Posted : Monday, September 8, 2008 2:39:54 PM(UTC)
I'm glad you were able to fix it.
alex100
#9 Posted : Thursday, September 10, 2009 9:47:15 PM(UTC)
alex100
Tim
As this thread is really old, I want to make sure that I'm getting the right part.
I have the same make and model as Tim had, Amana ARTSC8651SS and I also have diagnosed the problem (F1) to be a shorted membrane (Thanks to the help of this awesome forum!!!) I took the panel apart and disconnected the ribbon and powered the oven back on and the beeping noise stopped, the timer was flashing. I can still use the electric top but the oven panel is now disconnected.
I went to the parts diagram and the BLACK membrane that I need is listed as part number AP4039872. Am I looking at the right part here? Did Tim's part number get changed over time to this new one I found?
I'm just trying to make sure since it's an expensive part!!
Thank you so much for this awesome website, I've never would have attempted to fix it myself it if were not for this site!!! THANK YOU SO MUCH!!!!
PS> The part I'm referring to from Tim's post is what he calls part number AP93441-Membrane, switch panel (bl).
Thank you all again!!
Alex.
#10 Posted : Sunday, September 13, 2009 4:22:44 PM(UTC)
Hi Alex,
The part number you found is the correct part number and it has been changed by the manufacturer since Tim posted his question.
- The black membrane switch Part number: AP4039872
How to fix a EO F1 error code (Oven Repair (including Ranges and Cooktops))
by Guest 10/16/2022 10:15:19 AM(UTC)
IN DESPERATE NEED OF HELP - Double F1 Error Code (Oven Repair (including Ranges and Cooktops))
by A87CEO 9/8/2021 7:16:47 PM(UTC)
Whirlpool Dryer Cabrio F1 Error Code (Dryer Repair)
by thuynh28105 7/21/2013 7:21:24 PM(UTC)
Kenmore HE2 F11 and F1 error code (Washer Repair)
by peaks 10/6/2012 11:08:57 PM(UTC)
F1 error code on after controller replacement (Oven Repair (including Ranges and Cooktops))
by ski1965 6/16/2012 12:07:07 PM(UTC)
Whirlpool Cabrio F1 Error Code Assistance (Washer Repair)
by twhittaker 4/16/2012 12:08:48 PM(UTC)
F1 Error Code on Jenn Aire/ Kenmore Downdraft (Oven Repair (including Ranges and Cooktops))
by DownDraftBlues 12/6/2011 4:21:00 PM(UTC)
F1 error code - (Oven Repair (including Ranges and Cooktops))
by kennyskywalker 11/22/2011 9:57:42 AM(UTC)
Determining F1 Error Code (Washer Repair)
by lla56 11/3/2011 6:45:53 AM(UTC)
Kenmore Elite Washer F1 Error Code (Washer Repair)
by garystarh 6/9/2011 9:07:36 AM(UTC)
Kenmore Elite Oasis HE F1 error code (Washer Repair)
by pwc61 5/6/2011 5:47:06 PM(UTC)
by backatya07 4/22/2011 11:27:50 AM(UTC)
F1 error code on Fridgidaire oven (Oven Repair (including Ranges and Cooktops))
by imatourist 4/15/2011 8:20:26 AM(UTC)
F1 error code on Whirpool Cabrio (Washer Repair)
by bethwatts 3/17/2011 3:51:56 AM(UTC)
Kenmore Washer F1 error code (Washer Repair)
by RoxieD 9/2/2010 12:31:57 PM(UTC)
2 Pages12>
