backatya07
#1 Posted : Friday, April 22, 2011 11:27:50 AM(UTC)
backatya07
I am getting a continuous beeping and flashing on the control panel - Sometimes a F1 error code -
Any idea's
#2 Posted : Monday, April 25, 2011 7:18:37 AM(UTC)
Replacement parts for ARTSC8650E models | AppliancePartsPros.com
The error shows as a shorted key.
Best way to trouble shot is to unplug the unit, then unplug the ribbon cable from the control board and check the keypad with a meter to confirm a shorted key.
Or
You could unplug the unit and the keypad from the control board.
Then plug the unit in.
If the beeping continues odds are it is the control board.
If beeping stops then I would replace the keypad.
This is a bit of a crap shoot but your odds are better.
backatya07
#3 Posted : Saturday, April 30, 2011 5:27:32 PM(UTC)
backatya07
Thanks for your reply - Must appreciated !!
#4 Posted : Sunday, May 1, 2011 9:24:42 AM(UTC)
You are welcome
Hopefully it will help you get the correct part the first time.
How to fix a EO F1 error code (Oven Repair (including Ranges and Cooktops))
by Guest 10/16/2022 10:15:19 AM(UTC)
IN DESPERATE NEED OF HELP - Double F1 Error Code (Oven Repair (including Ranges and Cooktops))
by A87CEO 9/8/2021 7:16:47 PM(UTC)
Whirlpool Dryer Cabrio F1 Error Code (Dryer Repair)
by thuynh28105 7/21/2013 7:21:24 PM(UTC)
Kenmore HE2 F11 and F1 error code (Washer Repair)
by peaks 10/6/2012 11:08:57 PM(UTC)
F1 error code on after controller replacement (Oven Repair (including Ranges and Cooktops))
by ski1965 6/16/2012 12:07:07 PM(UTC)
Whirlpool Cabrio F1 Error Code Assistance (Washer Repair)
by twhittaker 4/16/2012 12:08:48 PM(UTC)
F1 Error Code on Jenn Aire/ Kenmore Downdraft (Oven Repair (including Ranges and Cooktops))
by DownDraftBlues 12/6/2011 4:21:00 PM(UTC)
F1 error code - (Oven Repair (including Ranges and Cooktops))
by kennyskywalker 11/22/2011 9:57:42 AM(UTC)
Determining F1 Error Code (Washer Repair)
by lla56 11/3/2011 6:45:53 AM(UTC)
Kenmore Elite Washer F1 Error Code (Washer Repair)
by garystarh 6/9/2011 9:07:36 AM(UTC)
Kenmore Elite Oasis HE F1 error code (Washer Repair)
by pwc61 5/6/2011 5:47:06 PM(UTC)
F1 error code on Fridgidaire oven (Oven Repair (including Ranges and Cooktops))
by imatourist 4/15/2011 8:20:26 AM(UTC)
F1 error code on Whirpool Cabrio (Washer Repair)
by bethwatts 3/17/2011 3:51:56 AM(UTC)
Kenmore Washer F1 error code (Washer Repair)
by RoxieD 9/2/2010 12:31:57 PM(UTC)
by Lennise 8/30/2010 1:16:24 PM(UTC)
