I am getting a F1 error message after my machine locks and it's trying to start. I push cancel and do push start again and the same thing happens. After the third time, it appears this error message is overridden and I can begin my washing. What is going on? I have read several blogs from other customer on the exact same issue and there seems to be a warranty, all labor, parts are covered at no expesne to the customer. pls assist..
The error indicates a failure of the main CCU that operates the machine.
You can find tech notes for diagnostic under the top of the machine.
Also, just because it indicates the CCU must be replaced doesn't mean that for sure replacing it will fix it. If you buy from this site and the part does not fix your machine you can return it, see the returns policy for details and conditions.
