OHCA
#1 Posted : Sunday, August 16, 2009 11:19:37 AM(UTC)
OHCA
HI, I HAVE A PROBLEM WITH THE TIMER KNOB. IT QUIT WORKING, ONCE YOU SET THE KNOB & YOU PULL IT SO THE WATER WILL START TO COME OUT, NOTHING HAPPENS. MY QUESTION IS, DO I NEED A NEW TIMER.:confused:
sidfink43
#2 Posted : Monday, August 17, 2009 3:23:03 PM(UTC)
sidfink43
Use a meter to check and see that you are getting 120v to the timer. if so, then test to see that you are getting 120v to the water valves.
If you are not getting 120v to the timer, you probably have a wiring problem.
If you are getting 120 volts to the timer but not to the water valves, replacing the timer is a good option, and since it is inexpensive I would see if that does not fix the problem. Here is the part.
Part number: AP4027898
If you are getting 120v to the valves, then I would try replacing the valves.
Good luck
Maytage washer timer knob (Washer Repair)
by captiveinflorida 11/1/2020 12:31:57 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Timer knob skirt of my Maytag dryer MDE3500AYW does not advance. (Dryer Repair)
by Panayiotis C. Papasavvas 7/23/2019 1:08:45 PM(UTC)
Timer Knob (Cycle Selector Knob) not Pushing In/Out (Washer Repair)
by crosis 9/16/2017 3:24:46 PM(UTC)
by crosis 9/16/2017 3:24:45 PM(UTC)
GE timer knob? (Dishwasher Repair)
by spaldini101 10/2/2014 5:55:06 AM(UTC)
broke off washer timer knob in moving (Washer Repair)
by todddavid 6/6/2014 2:16:32 PM(UTC)
Kenmore Timer Knob (Washer Repair)
by BILLK99 12/16/2013 4:04:28 PM(UTC)
Dryer starts and stops if I hold timer knob it stays on (Dryer Repair)
by Roger71 10/23/2013 4:12:40 PM(UTC)
Timer Knob removal (Washer Repair)
by dcblawdog 4/1/2013 3:46:42 PM(UTC)
Timer knob removal (Washer Repair)
by 71rrbob 2/25/2013 2:55:48 PM(UTC)
Maytag Atlantis washer timer knob removal (Washer Repair)
by roxytack 1/2/2013 4:04:26 PM(UTC)
Timer knob stuck (Washer Repair)
by segers41 12/9/2012 7:34:54 PM(UTC)
Can't remove Dryer timer knob (Dryer Repair)
by GPro 11/12/2012 2:16:39 PM(UTC)
timer knob will not advance (Dryer Repair)
by mrsvcj1 8/14/2012 7:42:16 PM(UTC)
