dcblawdog
#1 Posted : 12 years ago
dcblawdog
I'm trying to replace the timer knob, which broke completely. The stem is still attached to the timer shaft, and I can't remove it. Through my research, I think I'm supposed to see some type of clip holding the stem, but I see none - maybe it broke off when the knob itself broke? Can someone tell me how to remove the old knob shaft so I can install the new button? Also, will a need a new clamp/clip? One didn't come with the new knob, and I didn't see one on the exploded diagram for the control panel.
Thanks in advance!
sidfink43
#2 Posted : 12 years ago
sidfink43
You need to get access to the back of the timer. In the center is a hole. Insert a small screwdriver in the hole and life up (do this gently) and this will release the timer knob.
I don't think you need a new clip as the one that holds the knob is in the timer itself.
dcblawdog
#3 Posted : 12 years ago
dcblawdog
I can't get anything to release. The hole you mention is the hole where I can see the timer stem, correct?
sidfink43
#4 Posted : 12 years ago
sidfink43
Right, you won't be able to see anything but inserting the small screw driver should be able to let you release the remains of the knob, unless somehow the force that broke the know somehow damaged things inside the timer.
The back of your timer should look like this.
Whirlpool 21001522 Timer - AppliancePartsPros.com
dcblawdog
#5 Posted : 12 years ago
dcblawdog
I got it! All is good. Thanks a lot for your help and saving me $90 in a service call. If there's a way I can rate your help or give you kudos, please let me know. Thanks again.
sidfink43
#6 Posted : 12 years ago
sidfink43
Great, glad you got it removed. Those of us who reply on this Forum are volunteers and we do so in order to allow folks like yourself to avoid an expensive service call when you can do the job, so no thanks or kudos needed.
Good luck with your machine.
Timer knob removal (Washer Repair)
by 71rrbob 12 years ago
Maytag Atlantis washer timer knob removal (Washer Repair)
by roxytack 12 years ago
GE Dryer timer knob removal (Washer Repair)
by sosc1 13 years ago
by matt999 13 years ago
by mnestell 13 years ago
Timer Knob Removal (Washer Repair)
by DadOfEight 14 years ago
by phillmd 14 years ago
Sears timer knob removal (Washer Repair)
by all10thumbs 15 years ago
Timer Knob Removal (Dryer Repair)
by courtf 15 years ago
Maytag Performa washer timer knob removal? (Washer Repair)
by Albert P 15 years ago
Washing Machine Timer Knob removal (Washer Repair)
by jfb 15 years ago
Washer Timer Knob Removal (Washer Repair)
by SWENSON 16 years ago
by bill hack 16 years ago
