2 Pages12>
balutbob
#1 Posted : Monday, July 20, 2009 8:11:17 AM(UTC)
balutbob
Freezer / reefer quit working. Unplugged for a couple of hours. Plugged back in unit got cold for a couple of days then quit getting cold again. Compressor is running, condensor fan running, coils clean, temperature controls work, have output from circuit card. Although unit is not getting cold it cycles through defrost mode after being plugged in for a few hours ( determined by output on circuit card defrost terminal)
Any suggestions?
#2 Posted : Monday, July 20, 2009 10:42:42 AM(UTC)
Originally Posted by: balutbob Go to Quoted Post
...Compressor is running, condensor fan running, coils clean...
Which coils - condenser or evaporator?
If you meant the evaporator coils then there is a problem with the sealed system.
Here are the breakdown diagrams and Replacement parts for FRG FRS23H5ASB7 | AppliancePartsPros.com
balutbob
#3 Posted : Tuesday, July 21, 2009 1:59:48 AM(UTC)
balutbob
thanks for your reply
Condensor ..... haven't got into the evaporator side yet.... what do you consider as clean on evaporator coil ... free of ice? Should I open up back of freezer compartment to look at it? After being unplugged for a couple of days I would think it was free of ice. Don't understand why it goes into defrost when freezer not cold. Does it do this even though it's not cold? Thinking system may have lost charge, there is a green tarnish on areas of tubing from compressor. Indication of a leak?
#4 Posted : Tuesday, July 21, 2009 12:10:21 PM(UTC)
Quote:
...what do you consider as clean on evaporator coil ... free of ice?...
Yes.
Quote:
...Should I open up back of freezer compartment to look at it?...
Yes, but the refrigerator should be "on" for at least 2 days.
Quote:
...Don't understand why it goes into defrost when freezer not cold...
It does it by the time.
Quote:
...there is a green tarnish on areas of tubing from compressor. Indication of a leak?...
Probably not if there is no oil.
Check the evaporator and post the results.
balutbob
#5 Posted : Wednesday, July 22, 2009 1:05:20 AM(UTC)
balutbob
Thanks for your replies / suggestions Gene. I'll plug the darn thing back in and see what the evaporator coil looks like in a couple of days.
What controls the evap fan? Freezer control and thermostat? Thinking out loud, if evap coil is frosted fan should blow cold air into freezer, correct. :confused:
#6 Posted : Wednesday, July 22, 2009 11:52:03 AM(UTC)
Normally the evaporator coil should be about 100% covered with thin snow. The fan blows cold air into the fresh food compartment and spreads cold air through the freezer. It controls by the temperature control and should stay "on" while the compressor is "on".
balutbob
#7 Posted : Saturday, July 25, 2009 9:45:38 PM(UTC)
balutbob
I've had it plugged in for two days, No frost on the evap coil. Coil is not even cold. Fan is on
#8 Posted : Sunday, July 26, 2009 3:26:18 AM(UTC)
Pull off the back panel and check if condensing fan is working and compressor is running.
balutbob
#9 Posted : Sunday, July 26, 2009 9:04:04 AM(UTC)
balutbob
condensor fan and compressor are running
#10 Posted : Sunday, July 26, 2009 11:48:10 AM(UTC)
If you are sure the compressor is running, you have serious compressor problems if it is not compressing the refigerant.
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Fridge too warm due to one of two air vents in the fridge section of a fridge freezer not working (Refrigerator & Freezer Repair)
by mungbeans 7/15/2023 1:08:45 PM(UTC)
Refrigerator & Freezer not working after power outage (Refrigerator & Freezer Repair)
by fvigil57 12/2/2020 3:07:03 AM(UTC)
Chest freezer not working after capacitor replacement (Refrigerator & Freezer Repair)
by mtnmudder52 8/24/2019 3:52:34 PM(UTC)
Old Sub-Zero 532 (1987) freezer not working (Refrigerator & Freezer Repair)
by talerco 10/22/2018 8:05:58 PM(UTC)
by fme3535 7/24/2018 8:24:47 AM(UTC)
Freezer not working my freezer is (Refrigerator & Freezer Repair)
by Nive 3/31/2018 4:37:12 PM(UTC)
Fridge/freezer not working at all (Refrigerator & Freezer Repair)
by DrDeath2099 4/8/2017 1:06:30 PM(UTC)
Samsung RF26Hfendsr twin cooling freezer not working (Refrigerator & Freezer Repair)
by rwoltz 3/7/2017 11:21:00 PM(UTC)
Frigidaire upright freezer not working (Refrigerator & Freezer Repair)
by Hsalbeck 2/10/2017 12:05:48 PM(UTC)
by JamesA0625 11/1/2015 12:46:06 PM(UTC)
by jakubk 10/28/2015 6:41:44 AM(UTC)
Power outage, then the power is restored the refrigerator & freezer not working (Refrigerator & Freezer Repair)
by dhnhithe 10/3/2015 1:44:23 AM(UTC)
Whirpool freezer not working (Refrigerator & Freezer Repair)
by RootWood 8/21/2015 8:29:32 AM(UTC)
Whirlpool Refrigerator Freezer Not Working (Refrigerator & Freezer Repair)
by srbr 8/6/2015 6:24:04 PM(UTC)
2 Pages12>
