moby65
#1 Posted : Tuesday, June 16, 2009 6:08:14 PM(UTC)
moby65
top burners and broiler work but ove will not ignite. is the ignitor the only possible cause?
Dan O.
#2 Posted : Wednesday, June 17, 2009 9:52:38 AM(UTC)
Dan O.
Quote:
Model Number: XL 44
I'm afraid "XL44" is only a marketing name and not a model number which is what we need to find out what appliance design you're dealing with. You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
Quote:
broiler work but [bake burner] will not ignite.
What is the ignitor doing, glowing or not??
No but which component(s) might be suspect will depend on what the ignitor is doing.
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
moby65
#3 Posted : Sunday, June 21, 2009 3:59:40 PM(UTC)
moby65
ingnitor is not glowing
Dan O.
#4 Posted : Sunday, June 21, 2009 6:35:09 PM(UTC)
Dan O.
You still haven't supplied the appliance's model number so we can look it up.
Quote:
ignitor is not glowing
Than either the oven valve or the ignitor could have failed and have no continuity or the control system (whatever type that might be on your model) is not powering the ignition circuit.
JMO
Dan O.
=D~~~~~~
moby65
#5 Posted : Monday, June 22, 2009 5:01:30 PM(UTC)
moby65
model: JGBP3OAEP2AD
SER: ZG20882T9
if there is no ignitor glow should I check continuity?
Dan O.
#6 Posted : Tuesday, June 23, 2009 11:19:34 AM(UTC)
Dan O.
Yes, both the ignitor and the oven gas valve. If either has no continuity (ie. infinite resistance), it would be defective.
LINK > How do I test for continuity?
LINK > GE JGBP30AEP2AD Bake Ignitor
LINK > JGBP30AEP2AD Oven Gas Valve
JFYI
Dan O.
=D~~~~~~
Guest (4)
Whirlpool oven won't ignite unless unplugged and plugged back in. Thoughts? (Oven Repair (including Ranges and Cooktops))
by wbynum 12/20/2018 7:31:13 AM(UTC)
Oven won't ignite on bake initially but will after using broiler (Oven Repair (including Ranges and Cooktops))
by JeremySDMF 7/15/2015 11:06:20 AM(UTC)
Old Caloric oven won't ignite (Oven Repair (including Ranges and Cooktops))
by Alan McRae 6/17/2014 6:22:54 AM(UTC)
Thermador gas oven won't ignite/stay on (Oven Repair (including Ranges and Cooktops))
by 69GTFB 1/28/2013 11:57:57 AM(UTC)
Whirlpool Gas Oven won't Ignite (Oven Repair (including Ranges and Cooktops))
by davidshane 10/30/2012 11:25:32 AM(UTC)
Maytag gas oven won't ignite (Oven Repair (including Ranges and Cooktops))
by peterburns 9/12/2012 6:03:29 PM(UTC)
Whirlpool oven won't ignite after replacing igniter and valve (Oven Repair (including Ranges and Cooktops))
by Dave Mashburn 8/15/2012 9:57:46 AM(UTC)
Whirpool SC 465 - oven won't ignite... (Oven Repair (including Ranges and Cooktops))
by chappy801 5/22/2012 7:55:45 PM(UTC)
Kenmore Oven won't ignite (Oven Repair (including Ranges and Cooktops))
by nitramnaed 5/15/2012 6:57:11 AM(UTC)
KitchenAid oven won't ignite, except manually (Oven Repair (including Ranges and Cooktops))
by reneechgo 3/9/2012 3:46:03 PM(UTC)
by mwilli96 11/22/2010 4:50:35 AM(UTC)
Wall oven won't ignite (Oven Repair (including Ranges and Cooktops))
by Jeffjuiced 7/15/2010 12:02:17 PM(UTC)
Gas Oven Won't Ignite (Oven Repair (including Ranges and Cooktops))
by Jimh64 10/13/2009 1:30:16 PM(UTC)
by sandpointrick 9/16/2009 1:07:43 PM(UTC)
Amana Oven won't ignite (Oven Repair (including Ranges and Cooktops))
by MASOL 6/29/2009 5:43:20 AM(UTC)
