MisterR
#1 Posted : Friday, June 10, 2011 12:37:14 PM(UTC)
MisterR
Washer often times (40% of time) won't spin clothes dry.
Frigidaire Laundry Center, GLGH1462FS
It DOES fill, rotate both direction during wash & rinse & drains. IT FREQUENTLY WON'T SPIN THINGS DRY I don't overstuff or abuse in any way. It started doing this just after the 1 yr warranty period expired.
I've replaced the timer and the motor speed control board. The problem persists, same as before.
Any ideas what is causing this?
Searching web, it seems like I'm the only person in the world who has ever encountered this problem.
Thanks'
Mister R :confused:
sidfink43
#2 Posted : Sunday, June 12, 2011 3:09:28 PM(UTC)
sidfink43
If it goes through the spin cycle but the clothes are not dry check the pump and drain hoses for an obstruction. You would be amazed the stuff you will find in there.
MisterR
#3 Posted : Friday, June 17, 2011 4:13:12 AM(UTC)
MisterR
Maybe my description wasn't clear. Washer doesn't spin. It drains okay. It doesn't always Spin clothes. Any ideas?
Frigidaire Laundry Center Dryer Thermocouple replacement (Dryer Repair)
by Guest 8/26/2022 6:04:09 AM(UTC)
Frigidaire Laundry Center FUBAR (Washer Repair)
by tommy1673 1/20/2014 10:32:23 PM(UTC)
Frigidaire laundry center washer motor just hums for 5 seconds and shuts off (Washer Repair)
by rtlind83 3/8/2013 2:07:34 PM(UTC)
Frigidaire laundry center need to replace motor of dryer (Dryer Repair)
by suziguzzi 12/22/2011 4:55:43 AM(UTC)
Frigidaire Laundry Center Dryer Problem (Dryer Repair)
by dee50 6/30/2011 11:25:49 AM(UTC)
frigidaire laundry center washer will not fast spin (Washer Repair)
by keithb505 11/14/2010 7:13:53 AM(UTC)
Frigidaire Laundry Center confused (Washer Repair)
by rodrigo_umana 10/26/2010 6:54:12 PM(UTC)
Frigidaire Laundry Center Electric Dryer (Dryer Repair)
by speedfrk73z 9/22/2010 6:03:14 AM(UTC)
Frigidaire Laundry Center Fault Code E5 (Dryer Repair)
by blakeneys 1/25/2010 8:27:52 AM(UTC)
Frigidaire Laundry Center Slow Spin (Washer Repair)
by txtechnot 9/21/2009 1:55:18 PM(UTC)
Agitator for Frigidaire Laundry Center (Washer Repair)
by Gbear 12/11/2008 3:57:50 PM(UTC)
