AppliancePartsPros.com
Appliance Repair Help
Washer Repair
frigidaire laundry center washer will not fast spin
hi folks, the washer will not fast spin with cloths in it. the model # LEH1642DS0, when i take the cloths out it will work fine. i took the back cover off and the belt is not slipping. i even put a load of dry clothes in it to see if it was a balance issue and it still didn't work. I'm a little confused
thanks keith
Hi I Have A Front Loader Washer That Will Not Spin In Normal Cycle But When You Do The Dianostic Test It Does Display Keeps Flashin E47
Washer Repair
