tommy1673
#1 Posted : Monday, January 20, 2014 10:32:23 PM(UTC)
tommy1673
Bought a used but never ran frigidaire laundry center (they didn't have 220V power). It does nothing. Turn the dryer knob to start... nothing. Pull the washer dial... nothing. However, if you pull the the washer dial and then hold the dryer knob to start, the washer starts filling with water. If you release the dryer start button the water stops filling?? Any help would be appreciated. The back access panels have never had a tool on them and I put the electrical into this house myself (it was inspected through permit in the city I'm in.
#2 Posted : Wednesday, January 22, 2014 1:42:26 AM(UTC)
What is the model number?
Sounds like a power problem to me.
Check the power to the unit with a meter.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
What I think is happening is that you are missing half the line re: the L1 side. When you hold the dryer start you are creating an alternate path for the good side of the line and that is then powering up the washer fill valve.
Another thing to check is if the unit is wired correctly. re: it is wired for 3 wire and you are using 4 wire or the opposite. You should be able to find this in a manual online either an install or an operators manual.
