Washer often times (40% of time) won't spin clothes dry.
Frigidaire Laundry Center, GLGH1462FS
It DOES fill, rotate both direction during wash & rinse & drains. IT FREQUENTLY WON'T SPIN THINGS DRY I don't overstuff or abuse in any way. It started doing this just after the 1 yr warranty period expired.
I've replaced the timer and the motor speed control board. The problem persists, same as before.
Any ideas what is causing this?
Searching web, it seems like I'm the only person in the world who has ever encountered this problem.
Thanks'
Mister R :confused:
If it goes through the spin cycle but the clothes are not dry check the pump and drain hoses for an obstruction. You would be amazed the stuff you will find in there.
Maybe my description wasn't clear. Washer doesn't spin. It drains okay. It doesn't always Spin clothes. Any ideas?
