pendama
#1 Posted : Tuesday, February 3, 2009 8:46:01 AM(UTC)
pendama
I have replaced the door hinges 2 times in one year.
The springs weaken in a few months and the door won't stay shut. After a while the light will stay on because the door won't close.
Any help will be appreciated
John
#2 Posted : Wednesday, February 4, 2009 4:01:29 PM(UTC)
John,
What is the complete model number of the oven?
pendama
#3 Posted : Monday, February 9, 2009 9:44:24 AM(UTC)
pendama
The model # RBS305PDB2
I thought that the springs were getting weak from use or the heat, so
I moved the upper pin to lengthen the spring, but that didn't work.
The hinges have been replaced 2X and they work fine for a couple of months and then won't keep the door shut.
This time I put a 1/4 shim behind the upper screw in the hinge and it works just fine, we'll see how long this works.
Thanks for your time.
John
#4 Posted : Monday, February 9, 2009 12:47:12 PM(UTC)
Keep us posted.
pendama
#5 Posted : Thursday, May 7, 2009 10:03:43 AM(UTC)
pendama
On 2/09 I posted that I had put a 1/4 shim behind the upper screw of a whirpool oven spring assy, it is still working just fine.
John
#6 Posted : Thursday, May 7, 2009 4:36:47 PM(UTC)
John,
Thank you for your reply. I'm glad you were able to fix it.
GE Monogram Electric Wall Oven Model No. Z EK938SM1SS (Oven Repair (including Ranges and Cooktops))
by Govtman 11/14/2023 7:24:46 PM(UTC)
1970 GE electric wall oven (double oven) broken temperature sensor (Oven Repair (including Ranges and Cooktops))
by zea3 6/21/2022 1:48:00 PM(UTC)
Electric wall oven - not maintaining heat (Oven Repair (including Ranges and Cooktops))
by edjimene 4/2/2020 1:52:52 PM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
Electric Wall Oven broiler element stays on (Oven Repair (including Ranges and Cooktops))
by magicman1963 12/26/2016 6:29:18 PM(UTC)
30" Jenn-air single electric wall oven (Oven Repair (including Ranges and Cooktops))
by dubina 7/6/2015 12:41:55 PM(UTC)
Viking Electric Wall Oven (Oven Repair (including Ranges and Cooktops))
by bcnelson65 1/7/2014 4:14:31 PM(UTC)
Thermador Electric Wall Oven does not turn on (Oven Repair (including Ranges and Cooktops))
by fw500 12/4/2013 9:51:17 PM(UTC)
kenmore electric wall oven still wont work after several workarounds (Oven Repair (including Ranges and Cooktops))
by Pinkman 10/20/2013 1:33:03 PM(UTC)
Magic Chef Electric Wall Oven - Top oven will not warm to set temp (Oven Repair (including Ranges and Cooktops))
by danimalotr 5/28/2013 4:28:17 PM(UTC)
by danimalotr 5/28/2013 4:28:02 PM(UTC)
Whirlpool Accubake Double Electric Wall Oven (Oven Repair (including Ranges and Cooktops))
by chrisgoldsmith 4/26/2013 6:11:04 PM(UTC)
Frigidaire electric wall oven won't heat (Oven Repair (including Ranges and Cooktops))
by patruttle 2/28/2013 9:39:02 AM(UTC)
Maytag electric wall oven control panel dead (Oven Repair (including Ranges and Cooktops))
by sandiegan 3/24/2012 3:37:37 PM(UTC)
Old GE electric wall oven (Oven Repair (including Ranges and Cooktops))
by L. Coble 12/28/2011 8:40:26 AM(UTC)
