magicman1963
#1 Posted : Monday, December 26, 2016 6:29:18 PM(UTC)
magicman1963
Our GE Built-In Oven has developed a problem where the top broiler element will not shut off when the front control panel is set to off. I've shut off the circuit breaker to the oven for more than an hour, and then when turning the circuit breaker back on, the broiler element automatically goes back on without anything on the front control panel being touched.
Any ideas?
Thanks.
ThatGuy
#2 Posted : Tuesday, December 27, 2016 11:16:18 AM(UTC)
ThatGuy
Groups: Expert
United States
I'd say the "broil" relay on you control board has welded its contacts together internally. Repair or replace. Your model number had an extra "0", but I think this might be the right one.
GE WB27T10272 Electronic Oven Control - AppliancePartsPros.com
magicman1963
#3 Posted : Tuesday, December 27, 2016 12:52:38 PM(UTC)
magicman1963
Thanks so much. I've attached photos of the Oven Model / Serial # tag as well as a photo of the control board part #. The Part # of the control board is WB27T10065 which cannot be found anywhere. Would love it if the part # that you replied with would replace it, but can you confirm given the pictures that I've attached?
Thanks again.
magicman1963 attached the following image(s):
ThatGuy
#4 Posted : Tuesday, December 27, 2016 3:21:18 PM(UTC)
ThatGuy
Groups: Expert
United States
Looks like the part is no longer available. Your best best is to find a repair service and have it fixed. I looked it up over at $ears and came up with the same number and unavailable there too.
