marie hornung
#1 Posted : Saturday, November 7, 2009 9:02:55 AM(UTC)
marie hornung
my dryer works for a while, then shuts off. the light also shuts off. When it shuts off, the dial stops turning. I replaced the thermostat last year and everything worked great. Now the problem is back.
#2 Posted : Sunday, November 8, 2009 1:33:55 AM(UTC)
Replacement parts for MAYTAG LDE8304ACE | AppliancePartsPros.com
Which light shuts off?
If you open the door and you do not have an interior light perhaps the door switch is acting up.
A thermostat should not cause this type of problem since they are in the heater circuit and not the motor circuit. Though there is usually a thermal fuse in the motor circuit but when this blows it does not reset.
Can you restart the machine right away just with the push to start?
If you have to wait a couple minutes before it will restart, this is often a motor problem. The motor is overheating, it's internal thermal cut-out trips and you have to wait till the motor cools down before you can restart.
marie hornung
#3 Posted : Sunday, November 8, 2009 4:55:08 AM(UTC)
marie hornung
Originally Posted by: denman Go to Quoted Post
I cannot start the machine right away. I have to wait a few minutes.
marie hornung
#4 Posted : Sunday, November 8, 2009 4:56:40 AM(UTC)
marie hornung
:confused:
#5 Posted : Sunday, November 8, 2009 5:45:31 AM(UTC)
Sounds like your motor is overheating.
Try turning the drum in the correct direction. It should turn fairly easily.
If not it may be overloading the motor causing it to overheat.
Open it up and check that the motor is not clogged solid with lint.
If both the above are OK then you probably need a new motor.
marie hornung
#6 Posted : Sunday, November 8, 2009 8:51:53 AM(UTC)
marie hornung
the drum turns easily, but it does not sound like it is running smoothly. It sounds like it may be off balance. What would cause this thumping sound?
#7 Posted : Sunday, November 8, 2009 12:28:30 PM(UTC)
Usually a thumping noise is a rear support roller.
Other causes could be a ripped drum seal or someting in the blower.
marie hornung
#8 Posted : Monday, November 9, 2009 11:26:47 AM(UTC)
marie hornung
the noise stopped (I pushed the fan into place), but the dryer still keeps shutting off. I did notice what I think is a thermostat near the fan. Could this need to be replaced? Sometimes it runs for a half hour, other times 10 minutes.:)
#9 Posted : Monday, November 9, 2009 2:22:32 PM(UTC)
This could be your problem. It could be stripped inside and is slipping on the shaft. I would remove it and inspect it.
marie hornung
#10 Posted : Wednesday, November 11, 2009 2:11:57 PM(UTC)
marie hornung
The noise has stopped and everything is perfect! The "c" shaped pin had stretched when I pulled out the fan and it was hitting. I tightened it and now the noise is gone. I pulled out the thermostat and found dust, just like you said. You guys are genious. Thanks for saving me big bucks. I'll be back the next time things go bad.:D
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Frigidaire model ferb5700ds0 electric dryer (Dryer Repair)
by rnh7133 7/29/2023 6:22:58 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Older Speed Queen electric dryer (Dryer Repair)
by Guest 3/29/2023 5:23:19 AM(UTC)
