camlog
#1 Posted : Monday, May 17, 2010 6:49:53 AM(UTC)
camlog
My refrigerator has been making a loud banging noise when it shuts off. I don't know if it's the compressor or not. Now it's not making the noise and the food side is not really cold and the freezer side doesn't seem to be that cold. Could it be the compressor needs to be replaced or could it be something else
#2 Posted : Monday, May 17, 2010 7:16:25 AM(UTC)
Odds are it is the compressor.
The loud banging on shut off is usually the compressor see the following
http://www.applianceaid.com/refrigerator.html
See Item 24.
A new compressor will be expensive as you need a pro.
Be sure to get a solid quote so that you can decide if it is worth the dollars or does it make more sense to put those dollars into a new unit.
Whirlpool LER7646EQ2 drum roller banging noise (Dryer Repair)
by ultrachrome 3/6/2022 1:03:29 PM(UTC)
washer makes loud banging noise on spin cycle (Washer Repair)
by shannank77 6/27/2021 9:16:49 PM(UTC)
Whirlpool Cabrio Washer banging noise at the spin cycle (Washer Repair)
by Guest 5/13/2021 2:33:38 PM(UTC)
Dryer making banging noise (Dryer Repair)
by maytagNewbie 12/14/2017 7:14:00 AM(UTC)
Maytag Centennial banging noise while spinning mode (Washer Repair)
by afnashcom 9/13/2016 8:40:41 PM(UTC)
Washer makes loud rubbing and now banging Noise (Washer Repair)
by Topmasters 7/5/2016 5:55:02 PM(UTC)
Whirlpool Duet wash basket out of balance, making banging noise (Washer Repair)
by relentless85 1/10/2016 1:30:22 PM(UTC)
GE Washer making banging noise (Washer Repair)
by Tony2shoes 1/31/2015 4:25:26 PM(UTC)
Help My Dryer Is Making A Thumping Banging Noise (Dryer Repair)
by rkschwer 9/23/2013 6:37:25 AM(UTC)
Kenmore washer making banging noise during agitation (Washer Repair)
by daverdfw 9/3/2013 9:48:38 AM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Loud banging noise at top final spin speed (Washer Repair)
by gmlavoie 12/11/2012 10:46:43 AM(UTC)
Loud banging noise during cycle. (Trash Compactor Repair)
by Don Herman 1/17/2012 3:42:14 AM(UTC)
by Tom Roberts 11/28/2011 6:58:52 AM(UTC)
Loud Banging noise on way down and up (Trash Compactor Repair)
by chrisawol 11/18/2011 3:01:48 PM(UTC)
