ultrachrome
#1 Posted : Sunday, March 6, 2022 1:03:29 PM(UTC)
ultrachrome
United States
With some loads, the dryer makes a clunking sound.
I inherited the dryer in 2010 and replaced the rear felt seal in 2017 and we moved it upstairs from the basement. Last year I noticed the clunking noise and replaced the drum rollers but this had no effect.
Taking it apart, I can now see that that the drum can move fore/aft enough to cause the lower left drum roller to bang into the retainers.
I see three possible parts to replace: rear felt, bearing ring, and front panel felt.
Wondering if I could get way with just replacing front panel felt or do I need to do the rear again? The bearing ring seems fine.
Thanks.
