rschwerdfeger
#1 Posted : Monday, April 12, 2010 11:39:14 AM(UTC)
rschwerdfeger
Dryer runs perferctly but never shuts off....turn dial to a setting, push start button and no problem, dryer starts except the dial will never move through a cycle. Ordered new timer assembly and installed, no change....dial still doesn't rotate on it's own through a cycle. Dryer heats and works ok just won't shut off unless you manually move the dial or open the door.
#2 Posted : Monday, April 12, 2010 4:14:51 PM(UTC)
According to the Tech sheet and wiring diagram looks like the problem is a bad control board (#42 on the diagram).
- The control board Part number: AP3713177
rschwerdfeger
#3 Posted : Thursday, April 22, 2010 8:06:17 PM(UTC)
rschwerdfeger
Gene,
I have now replaced the control board and the timer assembly and the dryer still runs but the timer dial stays stationary....what next??
Rick
rschwerdfeger
#4 Posted : Thursday, April 22, 2010 8:11:08 PM(UTC)
rschwerdfeger
Rick
#5 Posted : Thursday, April 22, 2010 10:55:41 PM(UTC)
How long time take to dry an average load on timed dry?
rschwerdfeger
#6 Posted : Friday, April 23, 2010 3:54:51 AM(UTC)
rschwerdfeger
Normal drying time, however, without the timer moving it's hard to say if it's taking longer to dry, doesn't seem to....when you open the door it's plenty warm inside....
Your thoughts?
#7 Posted : Friday, April 23, 2010 4:49:54 PM(UTC)
I'm stumped at this point. I will ask our experts to look into it.
sidfink43
#8 Posted : Monday, April 26, 2010 1:09:57 PM(UTC)
sidfink43
Hi Rick
I think all of us would have thought that replacing the timer and the board would have fixed things. Let's do this.
1. Check to see if the timer does not advance in all cycles, both automatic and timed.
2. Check to see if the timer will advance in timed no-heat or fluff cycle.
3. Check continuity of the wires between the board and the timer.
4. Set it on timed drying and see if you have 120v going to the timer motor.
Post the results and if I cannot shed any light on the problem this may help someone who is smarter than I am (of which there are many who reply on this Forum) make a suggestion.
#9 Posted : Tuesday, April 27, 2010 1:24:48 AM(UTC)
I am assuming that this unit used to work OK.
Sometimes people buy a used unit and someone has messed up the wiring.
As sindfink43 said put the unit into timed dry mode as this eliminates the board as a possible cause.
Does sound like a broken wire or a defective replacement timer.
Timer motor circuit path is: NEUTRAL , DOOR SWITCH , TIMER SWITCH 3 , TIMER MOTOR , timer contacts BU/BK , L1
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
