WED9400sw running very hot error code f23 and f25 flash in diagnostic mode \and for short time a 72(or73) code flashed replaced outlet thermistor and fuse.(checked old fuse and had ~12-14K ohms(similar to new one)) still flashing same codes checked inlet thermister and sensor(lg terminal) are in continuity and small plug terminals show ~50k ohms (which I think is ok) unsure about replacing inlet for ~$50 as it appears good, like outlet thermistor wondering if it is the board checked P4 3 vs p36 wires and measure ~12Kand p8-3 vs p9-1 were similar what to do next?
