phat9
#1 Posted : Sunday, March 28, 2010 8:05:56 AM(UTC)
phat9
i got flood couple week ago. water level just over the control center unit. Now evry time i turn it on, water go in then stop and door click unlock. It show display affichage F28...Serial Communication Error. Wonder if any1 can help
Thank you in advance!
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore Elite Washer HE 3T (Washer Repair)
by loilanh 5/12/2020 10:08:29 PM(UTC)
Kenmore Elite Washer Baffle Replacement (Washer Repair)
by lkdykens 5/3/2020 8:54:41 PM(UTC)
Kenmore Elite washer, no power to drain pump? (Washer Repair)
by David L. Mandel 8/4/2019 10:12:08 PM(UTC)
Kenmore Elite Washer lost cycle control (Washer Repair)
by Lion8360 11/23/2015 7:31:56 AM(UTC)
Kenmore Elite Washer Oasis HE (Washer Repair)
by Charlese 8/17/2015 11:15:49 AM(UTC)
Kenmore Elite Washer Possible Motor/Transmission/Gearcase Problem (Washer Repair)
by USCgEEk 8/16/2015 10:03:26 PM(UTC)
Kenmore Elite washer tripping breaker after it fills up. (Washer Repair)
by ElleG79 3/17/2015 3:21:13 PM(UTC)
Kenmore Elite washer will drain but does not agitate. (Washer Repair)
by thellamattina 12/3/2014 3:44:17 PM(UTC)
kenmore elite washer dl code in spin cycle (Washer Repair)
by THE FIXER 9/7/2014 7:01:57 PM(UTC)
Kenmore Elite washer not draining or spinning (Washer Repair)
by cadrin16 3/24/2014 10:54:33 AM(UTC)
Help identify part Kenmore Elite Washer - sort of a "clevis pin" (Washer Repair)
by rsaritzky 1/27/2013 7:40:45 AM(UTC)
Kenmore Elite Washer Not Changing Cycles (Washer Repair)
by maxruby 1/20/2013 5:23:05 PM(UTC)
Kenmore Elite washer agitates OK for 10 sec, then stops (Washer Repair)
by wodag 11/20/2012 9:35:19 AM(UTC)
Kenmore Elite Washer (Washer Repair)
by stirmon 10/27/2012 1:18:09 PM(UTC)
