jimjelly
#1 Posted : Thursday, March 25, 2010 1:58:03 PM(UTC)
jimjelly
I replaced the heating element ordered on-line. Got it installed and the dryer still does not heat up. I have checked the fuse and have continuity. What else do I need to check?
#2 Posted : Thursday, March 25, 2010 6:41:32 PM(UTC)
What happened with the old heating element? Did you test it?
jimjelly
#3 Posted : Thursday, March 25, 2010 6:46:39 PM(UTC)
jimjelly
Still have it..when I read it with a meter, it showed an open. I am getting voltage before the thermal cut-off, but not at the cutoff itself. Of course no voltage to heating element. But, the cut-off reads correctly from what the wiring diagram shows.
#4 Posted : Thursday, March 25, 2010 7:37:25 PM(UTC)
Originally Posted by: jimjelly Go to Quoted Post
...I am getting voltage before the thermal cut-off, but not at the cutoff itself...
Can you be more specific here?
Can you refer the test points to the wiring diagram?
jimjelly
#5 Posted : Thursday, March 25, 2010 9:21:47 PM(UTC)
jimjelly
At the bottom of the wiring diagram...R I guess is where I am talking about taking a reading. Have voltage up to there.
#6 Posted : Friday, March 26, 2010 11:44:07 AM(UTC)
If there is the correct voltage reading at the timer terminal "R" (red) but there is nothing at the other end of the red wire at the thermal cut off, then the problem is a broken red wire.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
