debjames
#1 Posted : Wednesday, May 14, 2008 2:41:46 PM(UTC)
debjames
My machine stopped working about a month ago after it filled for the wash cycle. All it did wass buzz or hum. I siphoned it out and I unplugged it. Prior to this there had been a small leak right under the basket.
Today I pulled it out to see what was wrong with it. I plugged it in and turned it on with the handwash - water level, extra short cycle and it completely went throught all cycles. I then started again to wash a small load of dishtowels and it filled and started buzzing again.
I tried to run the self-test on it but all it does is buzz.
Any ideas what needs to be repaired on this machine or should I just get rid of it.
Deb
#2 Posted : Thursday, May 15, 2008 1:59:58 PM(UTC)
Hi Deb,
Remove the rear access panel and check how hot is the motor. Most likely the problem is there.
- The part number for the motor is AP3094375
Here are the break down diagrams for the Whirlpool washer Model LA9800XPW1
debjames
#3 Posted : Wednesday, May 21, 2008 4:03:25 PM(UTC)
debjames
Thanks for the advise. I replaced the motor and the machine is now working agian on everything but jeans. The agitator stops working when the heavy jeans are in the tub. I looked under the machine at the drive system during the wash cycle and there is a pin (post) near the rear of the trany that pops up preventing the agitator from moving. How can I fix this problem.
Thanks in advance,
Deb James
#4 Posted : Wednesday, May 21, 2008 5:34:42 PM(UTC)
Hi Deb,
Check if the agitator cam bar (#16 on the break down diagram) is not worn out (where the plunger rivet is moving). Replace the agitator cam bar if it's bad. Replace the wig-wag (magnet control) assembly.
- The part number for the wig-wag assembly is AP3123061
- The part number for the agitator cam bar is AP2905585
P.S. There is a small chance for the trany to cause this problem and if this is the issue then it becomes a very serious problem due to unavailability of the part.
Viking dishwasher repair (Dishwasher Repair)
by AngelaH 8/29/2023 8:48:21 AM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
Appliances Repair North York || Dishwasher Repair (Refrigerator & Freezer Repair)
by digitallab 7/8/2021 8:45:33 AM(UTC)
LG Washer Repair (Washer Repair)
by 623-332-8543 1/10/2021 9:14:04 AM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Samsung dishwasher repair (Dishwasher Repair)
by Cougar6069 5/5/2020 6:01:38 PM(UTC)
Washer Repair Question (Washer Repair)
by Paladin7485 4/13/2020 7:59:46 AM(UTC)
Dishwasher repair - kitchenaid briva KIDS36EPSS0 (Dishwasher Repair)
by magicmarc 1/8/2020 5:56:50 AM(UTC)
Bosch SHU9915UC/U11 Dishwasher repair (Dishwasher Repair)
by Yariet 11/4/2019 6:35:40 AM(UTC)
washer repair foreign material in coin trap (Washer Repair)
by hleduc999 8/4/2019 9:30:00 AM(UTC)
Maytag Centennail Washer repair advice (Washer Repair)
by rmathieu75 1/6/2019 4:43:14 PM(UTC)
Bosch dishwasher repair (Dishwasher Repair)
by 66FSTbck 10/13/2018 7:34:04 AM(UTC)
Whirlpool Thin Twin Washer Repair Advice (Washer Repair)
by sdl5 3/8/2018 8:37:28 PM(UTC)
by PaulaRenee 2/16/2018 7:10:02 PM(UTC)
Portable Dishwasher Repair (Dishwasher Repair)
by cliff10 1/7/2018 8:53:54 AM(UTC)
