I have replaced the programmed control module at the base of the unit . This had to be done because it ended up being shorted out by a slug that committed suicide by entering in there somehow. It shorted out the panel in 2 spots. I have replaced it but the machine still does not power up. I checked and there is voltage coming all the way into the moule itself. Any ideas what else it could be? I checked the control module on the door itself and nothing there is shorted out. All the connectors have been checked that they are plugged in. I don't know what else could be wrong or where to check.
Good One
