hi, dishwasher was not doing the wash cycle (no water pumping thru spray arms, etc..) so i replaced the main pump, and did the drain pump while i had the unit up and out and upside down.
so cycle starts, i hear the first draining of any thing in washer, then the water fill, then when its supposed to 'wash' i get the humming/buzzing, and no water pumping!!! so im assuming the main pump capacity is bad.? thus the buzzing sound when the wash cycle is supposed to be working?
also, the capacitor part # AP3176402, and its discontinued, thus does any know of a replacement i can use for this capacitor? thank you.
