MODEL NUMBER SF365BEPN3 (WHIRLPOOL GAS RANGE)
MY BURNERS WORK MY BROILER WORKS, BUT THE OVEN WILL NOT
COME ON UNLESS I TAP ON THE BURNER VALVE LOCATED UNDERNEATH... :mad:
NOW I HAVE ALREADY REPLACED THE BURNER VALVE THINKING THAT WAS
THE PROBLEM BUT ITS STILL DOING THE SAME THING .
PLEASE HELP IF IT IS ANYTHING I COULD FIX MYSELF THAT WOULD
BE GREAT !!!!! :) BECAUSE I CANNOT AFFORD A TECHNICIAN .
Most likely your glow ignitor is bad. Ignitor must give the safety valve approx. 3 to 3.2 amps to it to open the valve. It can still glow AND be bad.
