dryer is squeaking or squealing very loudly when it is still cold..stops after it warms up...how do i check the pulleys? belt? Iddler?
If the squealing is comming from the drum the best thing to do is replace the drum support rollers, idler pulley and the belt at the same time. When replacing the rollers and pulley make sure the shaft that they ride on is clean before putting the new ones on.
