kschimmoeller
#1 Posted : Wednesday, March 19, 2008 4:10:16 PM(UTC)
kschimmoeller
Dryer runs but no heat. Checked the following:
thermal fuse = closed
Igniter = closed
Flame sensor = Closed
Gas valve coils check OK
cycling thermostat = closed across red and open across vilot
Timer checks OK
It has gas because I have been about to mess around and get it to fire but cannot recreat my messing around
Local appliance repair man is on a cruise???
Any suggestions?
#2 Posted : Wednesday, March 19, 2008 5:27:05 PM(UTC)
If the igniter glows and there is gas to the dryer but it does not light then the only failure suspect left is the gas valve.
- The part number for the gas valve is AP3083221
Here are the break down diagrams for the Whirlpool dryer Model GGQ9800LG1
kschimmoeller
#3 Posted : Thursday, March 20, 2008 4:32:17 PM(UTC)
kschimmoeller
It has gas and the ingniter does not glow. What to check next?
#4 Posted : Friday, March 21, 2008 6:09:23 PM(UTC)
Check the temperature switch on the control panel.
Also the cycling thermostat has to be replaced due to: "open across violet".
- The part number for the temperature switch is AP2947360
- The part number for the cycling thermostat is AP3045874
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
