bgivan
#1 Posted : Thursday, December 24, 2009 2:56:08 PM(UTC)
bgivan
My dryer shows 8.8 on the display and will not turn on. Power is on, the light in the drum is on, but it will not turn on. In the past when this happened if I would wait the 8.8 would go away and it then would work. Any clues/suggestions?
sidfink43
#2 Posted : Monday, December 28, 2009 11:36:37 AM(UTC)
sidfink43
Use this service manual to see if you can put the machine into a test/diagnosis mode. Your model is covered at the end.
I am thinking the problem is either your membrane switches or control unit, more like the membrane but since both of these are expensive parts see if you can get a diagnosis from the test.
Also check to make sure you are getting 120v to each side of the connection block, and 120v to the control board.
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
Belarus eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
