robo
#1 Posted : Monday, March 17, 2008 12:27:59 PM(UTC)
robo
Problems:
1. Door no longer latches (cling) when shut. Dishwasher will still wash
2. LED lights no longer work that indicate cycle time and wash cycle desired.
3. Any way to disable the beeping sound when dishwasher is finished?
Is the latch switch broken? If this is broken, does this control the LED lights on top of the door?
Let me know,
Robo
Carson1214
#2 Posted : Wednesday, March 19, 2008 6:54:16 AM(UTC)
Carson1214
If sounds like you have a latch problem - the latch does control which display lights are showing. You may have gotten the latch in the closed position when the door is open. If this is the case the lights on the front of the door will light and not the timer and lights on the top. If this is the case you will need to remove the outer door to access the latch and reset the latch into the correct position. Once the latch position is correct your door top light will work when the door is open.
The Beep
Turn the unit off and while holding the right "Cancel Drain" button turn the unit on. The "Cancel Drain" button lights will now be flashing, press the right button to scroll throught he beep volumes. When off or quiter shut the unit off to save the setting.
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3/31/2022 3:33:31 AM(UTC)
Kitchenaid dishwasher problem - water path question (Dishwasher Repair)
by bmsamson 2/6/2020 9:03:09 AM(UTC)
by 7Bucks 7/23/2015 11:29:42 AM(UTC)
Dishwasher problem (Dishwasher Repair)
by malinz 7/10/2015 5:38:35 AM(UTC)
dishwasher problem (Dishwasher Repair)
by pstreet40 5/23/2015 9:15:33 AM(UTC)
Whirlpool Dishwasher problem (Dishwasher Repair)
by Brum 11/14/2013 5:15:57 PM(UTC)
by Jackhandle 6/15/2013 8:54:28 PM(UTC)
Maytag Dishwasher Problem (Dishwasher Repair)
by jsarp 10/26/2012 10:25:35 AM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 9:14:41 AM(UTC)
Whirlpool Dishwasher Problem (Dishwasher Repair)
by bkwcheng 8/27/2012 11:36:19 PM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by Robert Derr 6/1/2012 8:15:04 AM(UTC)
Maytag dishwasher problem (Dishwasher Repair)
by shannonflo 5/28/2012 11:38:38 AM(UTC)
Maytag QuietSeries 200 Dishwasher problem (Dishwasher Repair)
by FixitDad64 3/2/2012 11:23:49 AM(UTC)
by redbiker 1/2/2012 4:53:09 PM(UTC)
