Hi -
Our Maytag D/W has weak water flow. I have checked all the plumbing inside the unit and it is now cleared of all debris. The impeller is intact and screens are clean. It drains properly, but does not produce enough water pressure to spray out of the jets. :confused:
Still waiting for a reply- I have bought the motor ass'y and will install tonight if I have enough time-
However- I need more input as to how to install the motor seal- I sure :eek:don't wanna mess that up!!
