dryerman101
#1 Posted : Saturday, December 19, 2009 5:39:47 AM(UTC)
dryerman101
On spin cycle washer does not spin and makes chattering noise.
sidfink43
#2 Posted : Sunday, December 20, 2009 3:24:41 PM(UTC)
sidfink43
Pull off the agitator and remove the tub and check this part.
Part number: AP2905773
To do it you will need this special tool.
Part number: AP4503397
If the drive block is ok, you will need to take off the cabinet and check out the clutch and brake assembly
dryerman101
#3 Posted : Monday, December 21, 2009 10:22:00 AM(UTC)
dryerman101
I checked the drive block ,it is o.k.,you said "check out the clutch and brake assembly", what should I look for, also ,I forgot to mention the agitator does not turn.
sidfink43
#4 Posted : Monday, December 21, 2009 10:43:50 AM(UTC)
sidfink43
Ok, new information from the patient changes the diagnosis and solution. Check out your motor coupling. This video will show you how. On the way in check to make sure the pump is not obstructed, but since you here noise I think that is the motor turning and what you hear is the broken coupling.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
dryerman101
#5 Posted : Tuesday, December 22, 2009 6:20:36 AM(UTC)
dryerman101
Hello, once again you guys are right it was the coupling,the video was great,thank you very much.
sidfink43
#6 Posted : Tuesday, December 22, 2009 1:20:05 PM(UTC)
sidfink43
Great, glad that is all that it was and thanks for the update. It is very helpful.
Happy Holiday Season for you and your family.
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
