On spin cycle washer does not spin and makes chattering noise.
Pull off the agitator and remove the tub and check this part. Part number: AP2905773
To do it you will need this special tool. Part number: AP4503397
If the drive block is ok, you will need to take off the cabinet and check out the clutch and brake assembly
I checked the drive block ,it is o.k.,you said "check out the clutch and brake assembly", what should I look for, also ,I forgot to mention the agitator does not turn.
Originally Posted by: sidfink43  Hello, once again you guys are right it was the coupling,the video was great,thank you very much.
Great, glad that is all that it was and thanks for the update. It is very helpful.
Happy Holiday Season for you and your family.
