Carlos
#1 Posted : Wednesday, March 12, 2008 2:42:59 PM(UTC)
Carlos
Maytag washer Amana type belt Broke: Replaced belt And Broke Again. Please Can somebody tell me What could be the problem.
#2 Posted : Thursday, March 13, 2008 12:04:01 PM(UTC)
Did the new belt broke right after installation?
Did the washer work with the new belt?
Post as much information as you can.
Carlos
#3 Posted : Thursday, March 13, 2008 12:14:13 PM(UTC)
Carlos
Matag Waher Amana type: Replaced belt,washer worked two days then belt broke again. What I noticed after replacing belt was that motor triped overload once or twice. Could it be bad transmision or some kind of bearing that needs to be replaced?. I turn trans with my hands and it turns easily. seems the problem arises during the spin cycle.
#4 Posted : Thursday, March 13, 2008 5:28:00 PM(UTC)
Most likely the problem is a bad transmission.
- The part number for the transmission is AP3444949
Here are the break down diagrams for the Amana washer Model SAV5600AWW
GE Dryer won't start/broken belt (Dryer Repair)
by dhmostyn 12/10/2012 5:31:42 PM(UTC)
Broken Belt (Washer Repair)
by rwiggin 10/25/2010 1:16:20 PM(UTC)
broken belt (Washer Repair)
by pierre johnson 8/21/2010 7:26:24 AM(UTC)
washer stop spinning found broken belt underneath machine (Washer Repair)
by Gouri Ramnarace 8/12/2010 7:04:31 AM(UTC)
by BRUCELOWE 6/11/2010 4:10:32 PM(UTC)
Amana washer broken belt, not turning, leaks from bottom (Washer Repair)
by JonTK 9/8/2009 9:13:04 AM(UTC)
by mpsals1111 7/19/2008 12:10:22 PM(UTC)
Whirlpool gas dryer won't turn, broken belt? (Dryer Repair)
by crusader66 6/22/2008 3:49:56 PM(UTC)
Whirlpool broken belt (Washer Repair)
by hopeonceagain 10/16/2007 12:44:02 PM(UTC)
