mpsals1111
#1 Posted : Saturday, July 19, 2008 12:10:22 PM(UTC)
mpsals1111
The belt broke on my dryer...how do I remove the drum to replace the belt?
#2 Posted : Sunday, July 20, 2008 1:44:57 AM(UTC)
Use a putty knife to push back the top panel clips and tilt the top back. Remove the front panel screws and remove front panel.
Rout the new belt around the drum with the grooved side against the drum.
Remove back panel and rout the belt around the pulley and motor shaft, there is only one way to put the belt on to get the proper tension .
GE Dryer won't start/broken belt (Dryer Repair)
by dhmostyn 12/10/2012 5:31:42 PM(UTC)
Broken Belt (Washer Repair)
by rwiggin 10/25/2010 1:16:20 PM(UTC)
broken belt (Washer Repair)
by pierre johnson 8/21/2010 7:26:24 AM(UTC)
washer stop spinning found broken belt underneath machine (Washer Repair)
by Gouri Ramnarace 8/12/2010 7:04:31 AM(UTC)
by BRUCELOWE 6/11/2010 4:10:32 PM(UTC)
Amana washer broken belt, not turning, leaks from bottom (Washer Repair)
by JonTK 9/8/2009 9:13:04 AM(UTC)
Whirlpool gas dryer won't turn, broken belt? (Dryer Repair)
by crusader66 6/22/2008 3:49:56 PM(UTC)
Broken belt (Washer Repair)
by Carlos 3/12/2008 2:42:59 PM(UTC)
Whirlpool broken belt (Washer Repair)
by hopeonceagain 10/16/2007 12:44:02 PM(UTC)
