pierre johnson
#1 Posted : Saturday, August 21, 2010 7:26:24 AM(UTC)
pierre johnson
my kenmore top load washer has a broken belt. do I have to take the motor out to replace the belt?
pierre johnson
#2 Posted : Saturday, August 21, 2010 7:30:47 AM(UTC)
pierre johnson
my kenmore top load washer has a broken belt, do i have to take the motor out to replace the belt?
applianceman
#3 Posted : Sunday, August 22, 2010 8:53:12 AM(UTC)
applianceman
I don’t believe you have given the correct model number. Most Kenmore washers are made by Whirlpool, which don’t have belts. We will need to model number to know for sure. If it is made by Whirlpool this page should help Whirlpool Washer Not Running Repair Guide
That page is for Whirlpool or Whirlpool made direct drive washers only.
GE Dryer won't start/broken belt (Dryer Repair)
by dhmostyn 12/10/2012 5:31:42 PM(UTC)
Broken Belt (Washer Repair)
by rwiggin 10/25/2010 1:16:20 PM(UTC)
washer stop spinning found broken belt underneath machine (Washer Repair)
by Gouri Ramnarace 8/12/2010 7:04:31 AM(UTC)
by BRUCELOWE 6/11/2010 4:10:32 PM(UTC)
Amana washer broken belt, not turning, leaks from bottom (Washer Repair)
by JonTK 9/8/2009 9:13:04 AM(UTC)
by mpsals1111 7/19/2008 12:10:22 PM(UTC)
Whirlpool gas dryer won't turn, broken belt? (Dryer Repair)
by crusader66 6/22/2008 3:49:56 PM(UTC)
Broken belt (Washer Repair)
by Carlos 3/12/2008 2:42:59 PM(UTC)
Whirlpool broken belt (Washer Repair)
by hopeonceagain 10/16/2007 12:44:02 PM(UTC)
