fills with water, goes thru wash cycle just fine, but will not spin out. changed the belt, still wont spin. can not turn the tub or agatator. is it worth fixing or get a new washer?
Remove the belts and check if the motor would work on spin.
when the motor runs, it spins. burns the belt if you let it
Having the same problem myself. Tracked it to a siezed up lower bearing. Motor runs, pumps out water, won't spin. Agitator and drum will only turn slightly by hand before they lock up. Looks like a new tranny or washing machine.
