Tallen
#1 Posted : Monday, December 7, 2009 1:59:54 PM(UTC)
Tallen
fills with water, goes thru wash cycle just fine, but will not spin out. changed the belt, still wont spin. can not turn the tub or agatator. is it worth fixing or get a new washer?
#2 Posted : Monday, December 7, 2009 3:20:08 PM(UTC)
Remove the belts and check if the motor would work on spin.
Tallen
#3 Posted : Monday, December 7, 2009 7:45:55 PM(UTC)
Tallen
when the motor runs, it spins. burns the belt if you let it
rkbouley
#4 Posted : Tuesday, December 8, 2009 8:50:43 AM(UTC)
rkbouley
Having the same problem myself. Tracked it to a siezed up lower bearing. Motor runs, pumps out water, won't spin. Agitator and drum will only turn slightly by hand before they lock up. Looks like a new tranny or washing machine.
#5 Posted : Tuesday, December 8, 2009 1:57:50 PM(UTC)
Sounds like the problem is a bad transmission. It can be repaired as instructed in the Service manual or replaced.
Here are the breakdown diagrams and Transmission replacement parts for MAYTAG LAT9200BAL Washer - Top Loading | AppliancePartsPros.com
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
