JILL H
#1 Posted : Tuesday, December 1, 2009 3:29:17 PM(UTC)
JILL H
The oven takes forever to reach the preheat temp that you set and even when it does I am not so sure that temp is correct.This all started after i self cleaned the oven after thanksgiving i lifted up the bottom element to clean the ash , could i have unpluged this element , it does not seem like it is getting hot , the top element works fine on broil and stove top works fine. Thanks for your help. Jill
anna123
#2 Posted : Monday, January 12, 2015 8:28:10 AM(UTC)
anna123
I have a Hotpoint electric oven that doesn't keep the correct temp. The model number is RB787WC5WW and the serial number is SD253463R. What do I do?:eek:
Hotpoint Electric Oven Lower Element (Oven Repair (including Ranges and Cooktops))
by merc1100sc 8/15/2016 12:22:37 PM(UTC)
Hotpoint Electric Oven Won't heat (Oven Repair (including Ranges and Cooktops))
by krausjw 2/22/2014 10:14:42 AM(UTC)
Hotpoint Electric oven not preheating (Oven Repair (including Ranges and Cooktops))
by 6470zzy 3/6/2011 12:10:24 PM(UTC)
Hotpoint Electric Oven Broiler Question (Oven Repair (including Ranges and Cooktops))
by DIYGuy 4/27/2009 3:35:12 PM(UTC)
