i have a kenmore heavy duty 70 series washer that has a hose off and leaks water and i dont know where the hose goes.
In order to provide most accurate advise I need the complete model number of the washer.
If you can post pictures of this hose, it might help too.
I have a Kenmore washer ..Model 110-24962301..type111 that is leaking under the bottom while the water is filling up....any solutions would be appreciated....Danny
Gene if you are getting this hllloer back at me please i am nes here
danthebassman07, Remove the washer cabinet and inspect all parts. Post the results. Gene.
Thx Gene for the response....I don't know if I can remove the cabinet on the washer....I have looked under it and found nothin leaking and checked the inlet hoses ...I guess I am over my head..
It is very simple to remove the washer cabinet - just click on the link in the previous reply and follow the instructions.
Thank you Gene...I didn't understand your post ..I will click the link....Danny
