I have a french door maytag with a bottom freezer which leaks water onto the floor quite often & will also frost up once in a while. What can I do? It also collects a lot of water which freezes & I have to take everything out & use my blow dryers to get out the ice.
I am going to assume that your model is a MFI2569YEW0 and not a MF12569YEW0. Below are the parts Parts for Maytag MFI2569YEW0 / - AppliancePartsPros.comTake a look at the drain item 31 in section 01. Click on the picture or part description for more info and a Q&A. Check that you have this type of drain as it looks like this is a kit to replace a problem drain system. |
THIS FORUM IS DEAD!!!!!!! |
