pestgirl
#1 Posted : Friday, August 22, 2014 6:56:20 AM(UTC)
pestgirl
I have a french door maytag with a bottom freezer which leaks water onto the floor quite often & will also frost up once in a while. What can I do? It also collects a lot of water which freezes & I have to take everything out & use my blow dryers to get out the ice.
#2 Posted : Saturday, August 23, 2014 8:09:19 AM(UTC)
I am going to assume that your model is a MFI2569YEW0 and not a MF12569YEW0.
Below are the parts
Parts for Maytag MFI2569YEW0 / - AppliancePartsPros.com
Take a look at the drain item 31 in section 01.
Click on the picture or part description for more info and a Q&A.
Check that you have this type of drain as it looks like this is a kit to replace a problem drain system.
